Scope Pro & Pulsar 2
fraz
Post by fraz »
Hi there,
Both these cards have a snake cable with audio connections on - I'm having work done at home and may have a "plate" put onto the wall so I can access the I/O more easily with the PC/ADAT etc.... being tucked away in another room and have the cabling ran through the house into the I/O "plate". My concerns are that both cards have their own snake cable with I/O on and I may not use all the connections and if I do use the connections on both cards I would need to run Pulsar 2 modules and scope modules, have a bigger "plate" on the wall as well which may complicate the projects but I would make use of the DSP's. I have thought of adding a DSP only board but would be limiting myself to 16 I/O via ADAT and would need to shell out more money for an additional DSP board.... :oops:
You folks have probably encountered this situation with working with Scope etc....and I'd be interested to hear your thoughts..... :D
Re: Scope Pro & Pulsar 2
you can use all available connections, including the ones on the Power Sampler card. if you don't need them, don't use them. please save the stress for a real problem. :lol:
fraz
Post by fraz »
OK Garyb thanks.... :lol:
