VOCODIZER WET/DRY
TomerTTB
VOCODIZER WET/DRY
Post by TomerTTB »
Hi all
I am trying to find a WET/DRY knob on the Pulsar VOCODIZER
Can any one help with this one? I want to play with the amount of the vocoder on my singing
Thank you :)
Tomer.
Mr Arkadin
Re: VOCODIZER WET/DRY
Post by Mr Arkadin »
Just take the output of Vocodizer and the mic output and route them to a mixer. Adjust to taste. Job done.
Jah Servant
Post by Jah Servant »
Make use of the beauty of Scope's routing possibilities.
I think vocoders generally don't work like that anyways, not like other effects. You aren't putting an effect on your voice with a vocoder you are using your voice (or whatever) to modify another sound. The 2 get blended into one, there is no dry or wet, it's vocoder or not. So do like suggested above, just use a separate channel for your vocals alone and mix to taste.
Or use autotune, set to an extreme setting, and use wet/dry there (Which is maybe the effect u were thinking of? Sometimes called the "Cher" effect or used very often in mainstream hiphop.)
petal
Post by petal »
valis wrote:Or use autotune...
shhhh!
Don't encourage him to use it...
Fluxpod
Post by Fluxpod »
shhhh!
Indeed! Autotune is crap.Not even good as some effect...god i have pictures of kanye west in my head now....... :x
TomerTTB
Post by TomerTTB »
GAY FISH :)
Thank you all I will try with the scope mixer
Tomer.
shhhh!
Sorry if my sarcasm didn't come through effectively enough :P
