4896 Mixer automation question.
snoopy4ever
Post by snoopy4ever »
Hello everybody.
I have a Tascam FW1884 surface controller, which is able to control any midi device, I was trying to assign midi controls to the 4896 mixer so I can mute/pan/fade etcetc.. however I've found the mixer (and seem all other devices :cry: ) do not accept more than 119 CC's. Is there a way I can get around that?.
Thanks.
Snoopy.
OK I've investigated a bit.. and found a fix on this.
Mixer can be set to accept all midi channels (omni).
each 8 channel group can be set to receive the same CC's BUT different Midi Channel ,
for instance channels 1-8 channel 1, 9-16 channel 2, etc etc.. so I can mute pan disable fade all channels on the mixer. The good part is the fw1884 allows me to program midi that way. :D what a relief.
Regards.
Snoopy
Re: 4896 Mixer automation question.
That should be in the Tips & Tricks thread it's so good.
I wonder if the other STM mixers use OMNI like that.
Having MIDI control like that is a blessing.
I use SpaceF Mixers because they have seperate MIDI channels for insert effects, and mixer functions.
MIDI in Scope is so elegant and easy.
