basati wrote:thanks!
but this player is to complicated. No need for attack/sustain etc. ... It need a midi signal to play.
and vdat dont work yet in v5.
and vdat play only files recordet by vdat - isnt it?
you could make vdat play other waves but you would have to trick it by putting them in a "adat" folder and they would have to be the same bitrate, length and depth as the ones allready there, for example if you wanted to play a wav you would have to crate the folder, create and name 8 WAV files appropriately, and then put your wav in place and with the same name as the first 2..
I would just make a vdat folder (with VDAT) as long as the longest one i would likely play, and then edit the wavs in sound forge or something to replace what exists there with what i wanted to play, Its a lot of hassle though.
hopefully if they update VDAT anyways, they might add the feature to play any wav file as well as the normal 8x tracks operation.
