I finally got these Oscillators as I am starting to make a giant live synth for Modular.
This patch is just the beginning.
In the XITE-1, Modular can be spread across several DSP's.
Having a MultiMode Oscillator w/ outputs for each waveform + Subs is a great idea, but having 2 x Multi's is way FAT.
The included pre's won't be useful because they are zone/song specific for my gig.
But since I am doing U2 the Fix and Simply Red '80's type of tunes now, I wanted some of those PPG 2.3 and Prophet VS sounds where the morphing of transpositions, mostly 5th's and Octaves were used. So hold the notes down to hear the morphing.
at0m's LFOtoMIDI and Medhi's CC2x2 devices are crucial. The evolving textures are because of these 2 devices.
The Sine LFO will slowly move from 50-60Hz to 320Hz which is attached to Flexor's CM Chorus.
The Mod wheel is on a couple presets attached to the PMod1 knob.
CC2 is not attached to anything, but is already set up in the CC Device and ready to place wherever you want.
MIDI A Source to the Merger, then to the C4T Patch.
LFOtoMIDI1 to CC2x2 to the Merger.
2 x seperate pathways are needed.
If I fucked anything up let me know.
C4T Slave & Syncmaster ( ONLY WORKS 4 XITE-!'s )
- roy thinnes
Re: C4T Slave & Syncmaster
Stardust, you're annoying me again
Turns out testing has proven that XITE-1's drivers are the issue.
So I renamed the topic.
Cheers.
