Question about sync plate.
philinb612
Post by philinb612 »
Hello.
I use Pulsar 1 and Pulsar 2 with S/TDM cable, and they are connected to A16 ultra and various a/d d/a converters.
I want to add sync plate.
Do I need two sync plates connecting each card?
or is just one enough?
Re: Question about sync plate.
one is plenty.
philinb612
garyb wrote:one is plenty.
thanks garyb.
kwild
Post by kwild »
If you need a syncplate im selling one.
Send me a PM.
______________________________
Mobile Suit ERA / Nu*ragika Recordz
http://myspace.com/mixmasterservice
http://myspace.com/_kwild
http://myspace.com/balentia
krizrox
Post by krizrox »
Just curious - is there any advantage to running a dedicated sync to Scope if you're using the Z-Link option from A16? Or is that mostly for ADAT transmission?
if you have a number of different digital devices that alll must be clocked together, bnc wordclock is the way to go. if it's just an AD/DA like the A16 and Scope card(s), then ADAT or better, Z-Link is perfectly fine.
muswell
Post by muswell »
krizrox wrote:Just curious - is there any advantage to running a dedicated sync to Scope if you're using the Z-Link option from A16? Or is that mostly for ADAT transmission?
How about it?
Would it work with Steinbergs' VST System link or are they fundamentally incompatible, eg "scope mode"?
what are you talking about? the syncplate is about digital sync between hardware.
kwild
Post by kwild »
How about it?
:o
