Compressor S not retaining Side Chain Connections
mausmuso
Post by mausmuso »
Hi There,
Not sure if this is a bug or not in Scope 5?
I used a Compressor S in an Insert in the 2448 Mixer to duck some keys under a vocal.
All worked fine, but after saving and reopening the project the SC connections were no longer there.
Anyone had this issue?
regards
maus
Re: Compressor S not retaining Side Chain Connections
Yepp........same here too.
The only Sidechaining I can have recalled is the DAS Gate w/ it's marvellous Keyed FIlters.
I stick it in an AUX and it works great.
But Vinco and other Sidechaining stuff from S|C seems to have a problem as inserts.
MCCY has some really sweet Sidechaining devices that retain settings.
But I usually use the DAS stuff.
mausmuso
Post by mausmuso »
Thanks Jimmy,
I only found this by accident as it was the first compressor I grabbed to look see what ducking would do for me in the mix
I might pass onto Soniccore just in case no-one else has registered it as a bug
maus
