Has anyone tried this?
Used to have a scope pro card.
Could never get it to work in XTC mode with no i/o.
People on the forum have got the 6 DSP card working with by shorting a jumper (which one ?)
Now, if you connect a 14 DSP card to a 6 DSP card via a STDM cable.
Then short out the jumper on the 6 DSP card for using the I/O on say protools or another sound card.
Does it work?
Can someone try this please!
regards,
James
6dsp card with 14dsp card with no i/o does it work
tripstation
tripstation
Re: 6dsp card with 14dsp card with no i/o does it work
oh no.
There is a double post.
how did that happen?
A double post.... and in the wrong forum.....
How did that happen.
Bad day on the intartubes eh??
I have a 14 & 6 dsp card connected via STDM used in conjunction with a Yam DS2416. Connecting pins 2&3 on the Pro card allowed both cards to be used in XTC without i/o.
If you search the forum there is a link to a document detailing getting the best out of XTC mode which details the above.
Si
Si
tripstation
Can the 14DSP card be used on its own in XTC mode without I/O by connecting pins 2 and 3?
Have you tried this?
tripstation
what forum should this post be in then.
Also what is the search string to find the thread you are referring to?
This will do the trick:
http://forums.planetz.com/viewtopic.php?f=32&t=21703
Yes a 14 dsp card can be used by shorting the same pins - you can then use it for XTC only.
Si
Si
tripstation wrote: what forum should this post be in then.
hehehe sorry ... just razzing ya.....
tripstation
He he.
I'm getting the feeling that scope cards still have a problem when running in a real dual processor system, especially with other cards like a Protools HD core, Powercore and UAD all at the same time.
I had problems before with my Asus PC-DL.
I might stay away from Scope until the problems are fixed.
I was hoping that they would be fixed in Scope 5.
Am I wrong?
Am I wrong?
