I just found the answer to my sts crashing problems.
First of all you will need at least 1gb memory.
Secondly to avoid crashes, at least in my system, I did the following...
My P4B-E asus is 133 fsb using old sdram 133 memory.
Now at bios settings I used 100 as fsb, instead of the maximum 133 , that maybe lowers the actual cpu frequency, but I don't care about that for the purpose of running a pc as a Pulsar STS hardware sampler !!!
Now I used 1:1 ratio for cpu/memory, meaning that the memory chips , two kingston value ram 512mb sticks, run at 100 instead of the maximum 133, that help them to run smoother...
ALSO I changed from the 2T to the 3T cas for memory and used 7 cas delay for ram.
I uncehcked all , lan, audio on board, parallel port, etc except for the usb and I have now for a couple of hours, at least, a very stable STS3000 running and loading 128 harddisk based instruments ALL at once and playing via program changes from a remote keyboard, all sounds by simply changing preset number buttons on the controller.
Hope this will help because the sound of STS sampling engine is UNBELIEAVABLE !!!!!
Regards,
Dimitrios
How to solve STS sampler problems (crashes etc...)
musurgio
