or simple sending midi cc from mixer fader, solo - mute button...
Someone - some can write code? It would be incredibly useful.
Reaper control surface for Scope
tjsound
XITE-1, Reaperx64...
- at0m
Re: Reaper control surface for Scope
tjsound,
I'm afraid the same goes for Reaper as for any control surface for Scope (I'm working on making some templates for my BCR2000): how the heck can you tune "your control surface", which is something static, to something as flexible as Scope?
Suppose you're being very specific on what device you want to control, you'd need a specific control surface or a specific set-up there-of, to make it go smooth. You'd need 10s if not 100s of them. And then we're just talking stock and TOTP 3rd party devices.
And then again, that's all in vein when something like a mixer with effects or a modular patch on its own can be so diverse, that any control surface's buttons/knobs/faders will fall short.
Here's some thoughts on remote controls. One could...
So before asking for a remote control surface, think deep, deeper, ... on what and how you want to control anything from Scope. Then you make up your mind, try thinking of some practical framework: how many knobs/buttons/faders do I have at my disposition, and which can I spare to assign to Scope parameters?
Hoping I didn't add to the confusion
at0m.
- mimic a generic device, like a big synth that will cover most common synth controls (bit like Minimax, with Pitch, Amp and Filter controls and ADSR, an LFO or 2-3, and a couple built-in effects (which params?)) or a mixer (volume, pan, mute, solo, aux send levels and 10'ish controls per channel for 2-3 inserts). But then how to control modulars, Solaris, Vectron or the STM2448?
- copy the lay-outs from all devices (yea right) and pre-assign CC# to them, and store MIDI presets for the Scope devices
- lay out a bunch of generic controls and assign them on-the-go. Then one can fine-tune in Scope, and remote control a selection of parameters that will evolve during the track. In Cubase, for example, each MIDI track has a bunch of generic controls, which I can automate using my BCF2000 in MC mode: volume, pan, etcetera. So I will assign those to a limited amount of controls of the corresponding Scope device: filter cutoff, amp envelope attack or release, ...
at0m.
tjsound
quite rightly, 16-32 faders on Reaper and may be mute-solo button must pass midi cc message to Scope, not more. then independently assign to the faders on my choice. the main problem as I think - an exact match 0 dB on Reaper and Scope faders
