Asio4all in Scope?
lagoausente
Asio4all in Scope?
Post by lagoausente »
I only can see the WaveRecPlay drivers on Asio4all, can´t see all the Asio Scope ins/outs. I´m doing something wrong or just is not posible?
luigicampala
Re: Asio4all in Scope?
Post by luigicampala »
Asio4all takes your wave-drivers and emeulates them as asio in/outputs.
If you want to get more in/outputs, you´ll have to add some wave-sources and wave-destinations in your scope projects. Maybe you´ll have to reboot.
The asio modules in your scope-project don´t matter at all
lagoausente
luigicampala wrote:Asio4all takes your wave-drivers and emeulates them as asio in/outputs.
Thanks for your reply, that wave drivers are 16 or 24 bit?
lagoausente, depends which you load in the project. I advise to always use the Wave 24bit drivers in Scope, and always load the amount of drivers as set in Windows' Device Manager > Scope driver properties.
And don't worry, 16bit applications will use these 24bit drivers just fine, so for example if you'd really want (for compatibility?) ASIO4ALL to provide 16bit ASIO, you can still set it to 16bit from ASIO4ALL.
lagoausente
at0m wrote:lagoausente, depends which you load in the project. I advise to always use the Wave 24bit drivers in Scope, and always load the amount of drivers as set in Windows' Device Manager > Scope driver properties.
With scope drivers can set latency till 3ms, maybe can lower this value with the Asio4all driver? Or is there any other way to controll the scope asio buffer samples?
voidar
Post by voidar »
The Wave drivers are broken. 24-bit source actually truncates to 16-bit. BTW
