cwmixers
roy thinnes
cwmixers
Post by roy thinnes »
I was fed up with the available mixers and made new ones:
download and infos here
Re: cwmixers
Far out, what - your kidding aren't you - this fir free? You beeyeewdy bro !!!!!
roy thinnes
Re: cwmixers
it's the cwm x-mas special
the19thbear
Re: cwmixers
Post by the19thbear »
This is freaking awesome!!!!!!!
erminardi
Re: cwmixers
Post by erminardi »
:o :o :o :o :o :o :o :o :o
Immanuel
Re: cwmixers
Post by Immanuel »
Those are beautiful and functional layouts. And I low the absence of numbers :)
Thank you!
Re: cwmixers
RoyT........
That was a very considerate thing to do.
New mixers are always appreciated.
erminardi
Re: cwmixers
Post by erminardi »
Channel 2 of big mixer has some txt into insert slots, maybe a little graphical bug?
Awesome devices!
Thanks Roy and merry X-Mas :)
roy thinnes
Re: cwmixers
thanks for your replies!
erminardi: this ain't no bug, it's a feature.
when you link channels, insert slots of link slaves (i.e. ch 2,4,...16) of course won't have their own (mono) insert.
instead the insert of the master channel (1,3,5...15) will become a stereo insert, and the slave serves as the right channel of it's master companion.
to remind the user, there is a text message (n[ot]a[vailable]), meaning that any loaded mono insert fx will be inactive, and can/should be removed to save dsp.
Re: cwmixers
I think it is a very good mixer for Kontakt/ASIO stuff.
I loaded 2 STW Reverbs and a pretty extreme Echo 35 Delay
from SpaceF.
I have all AUX's and BUSses enabled.
All EQ's are enabled, and I noticed the stero spread schem from
hard panning was already very wide, but I still inserted the
Stereo Expander in the Master Out slot.
Tested every EQ and every send/recieve and the only minute
detail I noticed was that the Mid Section of the EQ's when I
hover above them has no frequency display, and the Gain knobs
for each band, have no db display when hovering above.
THe High and Low bands do show their associated freq.s' displayed.
It's able to hold everything I put in it that I would use.
I only need EQ to cut Bass freq's from my analog synth, and never
use them on virtual synths, but with ASIO, or external audio I
always sprinkle some EQ's in the inserts.
These EQ's are fine and negate the need for an inserted EQ unless
maybe the DAS M/S effect is needed.
Real Nice Job CHeif.....
next to nothing
Re: cwmixers
Post by next to nothing »
Thanks, looks great!
t_tangent
Re: cwmixers
Post by t_tangent »
Thanks very much Roy. Much appreciated and look forward to trying this out later on today :)
Merry Christmas, and again, many thanks.
Tim
netguyjoel
Re: cwmixers
Post by netguyjoel »
WOW! You have done it AGAIN!
Many Thanx...
Joel
erminardi
Re: cwmixers
Post by erminardi »
roy thinnes wrote:thanks for your replies!
Oh, sorry Roy.
I'm dumb and you're the CWMaster! :lol:
Very very cool and accurate feature.
Thanks again :wink:
Fluxpod
Re: cwmixers
Post by Fluxpod »
Wow! Big thanks-Frohe Weihnachten und alles Gute für 2011! :)
roy thinnes
Re: cwmixers
thanks again, specially to JAV for extensive testing.
yes, for some (to me) unknown reason the bp filter gain and freq mouse-hover-info dosn't show up.
don't know if this is essential though - it would have been easy to implement text boxes for all eq gains + freqencies, but that would have required an even bigger panel, or an extra panel. (where also bp Q could be adjusted; btw: Q is set to zero for all channels.)
anyway, the filter frequencies are:
Hp 1kHz - 20kHz
Bp 300Hz - 2000Hz
Lp 20Hz - 400Hz
gain: -12 to +12 dB.
but, for sophisticated filter tasks someone should use designated filters anyway.
8) of course happy x-mas and nice presents for all of you! 8)
netguyjoel
Re: cwmixers
Thanx for the EQ clarification.....wish list...stereo channels...;)
Joel
siriusbliss
Re: cwmixers
Post by siriusbliss »
Excellent job!
Merry Happy everyone!
mausmuso
Re: cwmixers
Post by mausmuso »
Thanks Roy
Fills a bit of a hole in the mixer range.
Also it fits so neatly on a 24 inch monitor.
Small bug - if you unclick the 'Always On Top' button and click some devices that overlaps it, it does not go to the back.
Thanks very much its already in my default project
Have a great xmas
regards
maus
erminardi
Re: cwmixers
Post by erminardi »
dear Santa, my wish is... the 2 little CWM mixers (that are very DSP light) with at least 2 insert slots each channell :roll:
:wink:
Merry X-Mas to everybody!
