This software works only with Windows Seven or
hello, This software works only with Windows Seven or Windows Professional 64-bit edition
Re: This software works only with Windows Seven or
nunziata wrote:hello, This software works only with Windows Seven or Windows Professional 64-bit edition
- total no.gif (128.96 KiB) Viewed 2020 times
i say this becouse i have just istalled scope 5.1 64 bit on windows 64 bit ( i believe server 2003) and no works
I do not see the picture below is funny?
Type?
Type?
Type?
Type?
Yeah audiosoftware and Server os is not a good idea.I thought this was common knowledge.It also works on 32 bit win 7 and xp.
also, 5.1 needs new keys. if you are NOT using 64bit and you did NOT pay for the 5.1 upgrade, just use v5(if you paid for it or have v5 keys). there is no advantage to v5.1 over v5 except for 64bit.
i have payed, now again i try and then you to say
i want to move to 64 bits, such as software and not one problem with scope 5.1, cubase 6, wavelab 7, kontakt 4.5.
the most stable of all.
thanks
thanks
5.1 will work on Windows XP 64 which is the analogous of server 2003 .I have found that you need sometimes to make a switch in the asioscope .dll due to a minor bug that misinterprets the specific driver and its use .
Even though you havent given us much info on your system I understand that SCOPE loads but your DAW WONT PLAY THRU ASIO ? Please elaborate so that we might troubleshoot more accurately .
Regards Danny
Regards Danny
