motherboard dual xeon
nunziata
Post by nunziata »
Anybody know any motherboard dual xeon with 2 slot pci 33 mhz and 1 slot pcix 133 mhz for controller ultra 320 scsi ?
i want upgrade my harware for best performance -
CarvinGuitarFreak
Re: motherboard dual xeon
Post by CarvinGuitarFreak »
Hi nunziata,
I think the only Xeons that perform better than i7 and i5 at audio production (and everything else) are the 5600 series (based on i7 tech?). These cost a fortune to build.
Go for a i5 or i7 or the Sandbridge flavours. They are powerful, power efficient, quieter and cost a fraction of the server/workstation DAW.
Check out the following sites (if you haven't already):
http://www.adkproaudio.com/benchmarks.cfm
http://www.dawbench.com/dawbenchdsp-i7part1.htm
Regards,
CGF
(o)==][;;;;;;,;;;;;;;;;;;;;;;;;;;;,;;;;;;;;;;;,,,..
********CARVIN GUITARS RULE*********
..,,,;;;;;;;;,;;;;;;;;;;;;;;;;;;;;;;,;;;;;;;][==(o)
Neutron
Post by Neutron »
I tried XITE on my dual xeon "SR-2" which is all overclocked to hell, and it worked fine i only had it on there for about 9 hours of work though,
the only BSOD i ever had was with its normal place which is a "i7 875k"
nunziata
Post by nunziata »
maybe the problem is two slot pci 33 mhz for old card scope z -link-
new motherboard no have this slot -
thank
no, there are plenty of motherboards with pci slots. the problem is the pci-x slot. if you get rid of the scsi controller it will be easier. if you need raid, most motherboards support raid natively(sata). the scsi drives are obsolete.
for dual xeon socket 1366, there is intel and supermicro.
nunziata
Post by nunziata »
will be obsolete but they are very fast and then I have four, because they discard?
yes, unfortunately, if you want the latest hardware...
sata drives are just as fast.
nunziata
Post by nunziata »
then i buyed asus p6 w professional
chip i7 950 quad core 3,4
and 12 mb ram 1600 mhz team group
i hope well-
thank
nunziata
Post by nunziata »
I hope that put audio card in slot pcix 64/33mhz) x 2
Expansion Slots
PCI Express x16 x 1 • PCI x 1 • PCI Express x1 x 1 • PCI-X 64 Bit (66/33 MHz) x 2
Scope cards will not work in a pci-x slot, afaik.
