Maximum adat cable length
I want to use adat cables from 2 a16 ultra to 2 scope pci cards.
The length i need is about 15 meters (maybe i could get along with 10m).
So my questions are:
Has anyone used cables this long without problems (sync, jitter or any other quality issues)?
Any suggestions on brands?
What about plastic or glass?
I would really appreciate any help.
Thanks,
Panagiotis
Thanks,
Panagiotis
Re: Maximum adat cable length
i've used 50 foot cables quite successfully.
Thanks for the fast reply.
So what cable did you use (brand, plastic or glass)?
regular old hosa cheapies.
they're still being used in a professional studio.
actually, expensive, fancy optical cables often won't work well because the ends are too bulky and they don't fit in the sockets in space on the card well(too big, too close together).
- hosa optical cable.jpg (26.06 KiB) Viewed 3005 times
there are repeaters for long runs. technically, 10meters is supposed to be the maximum, so if you really want to be safe, go with that or use a repeater(amplifier) for longer. just sayin'....i have used 50 footers and they have worked(50ft=15m).
just handle them with (appropriate) care - avoiding sharp bends and walking over them...
I know from experience...
Well, that's great to hear.
So i guess i will try the hosa.
Since it works for you, there is no reason it won't work for me.
However, i found no EU dealer for the hosa cables (there is EU distribution but they don't seem to have a 15m cable available).
Any more suggestions from EU?
Well thanks for the advice.astroman wrote:just handle them with (appropriate) care - avoiding sharp bends and walking over them...
I know from experience...![]()
They will run through a plastic wire cover.
i don't know about the dealer situation, but the cable itself is not unusual or special.
Yes, i know.
However, a friend of mine is coming from the US, so i will get the cables soon enough.
Thank you all for your time.
I finally decided to order these cables
http://www.mutec-net.de/e_pro_cables.htm
These were the only ones i found in the EU that were above 10m (they have 15 nad 20 meters).
I ordered the 15m ones.
I will give you a short review as soon as i test them.
I hope there will be nothing to tell you except "they work as they should"
they sure look like the kind that would work....
I hope so.garyb wrote:![]()
Well guys, the cables arrived yesterday.
Just a few minutes ago, i connected everything together and.....they work like a charm.
No problems, no nothing.
Highly recommended.
Highly recommended.
I use a 30 foot (10m) cable to connect my XITE to an external A/D converter that sits under the main mixer for the band, which then has a short snake straight in/out of the board. My remote area then has a pair of ADAT cables, and a pair of MIDI. Easy to connect & disconnect my system between sessions.
