MidiTest on Scope boards
Music Manic
Post by Music Manic »
Hi guys,
I can't seem to get this program working:
http://miditest.earthvegaconnection.com/
I've created a loop in my problem board - Midi in to Midi out but MidiTester says it can't see the connection. How does the program recognise the ports?
Re: MidiTest on Scope boards
your routing windows should contain the construction as wired below (with your port numbers).
you may need to select from the API dropdown list.
On the screenshot 'kernel streaming' is highlighted, if that doesn't work something like 'multimedia' or MMI would be a valid option (dunno how it's programmed)...
Neutron
Post by Neutron »
I think almost all of the lag and jitter from that test will be from the operating system, drivers, and motherboard, rather than in the scope board itself.
