After a long time of hardware reverbs I decided to go the DSP models we have, and I must say with the XITE-1 converters they have a nicer sound quality, or maybe the STM2448X AUX Channels have been re worked.
I am using 2 x DAS RMX 160's and the STW Inverse.
For kick RMX #1, snare RMX 2#, and the Toms get the STW Inverse.
They work fine, but now that I have this error message, I became concerned.
No problem, I just OK my way through and everything works perfectly, but check out this weird Error message...........
Anyone ever seen this before..?
							STW Inverse 4 Toms
Re: STW Inverse 4 Toms
Well the way to avoid the Error message is to make sure on start up I use an STM2448X preset that doesn't have the STW Inverse loaded.
But then open the preset where it resides, i.e. for the Toms, and voila......No Error.
I have no answer but maybe the scientists and nullifiers can explain this.
Meanwhile I will make sure to load up a stored mixer preset, where the RMX160SC's and all other devices/effects are loaded. Then just add the STW or reload another preset and wait longer........
I just love talkiing to myself, so I'll answer my own questions in hopes this might help others.
Upon further scientific testing I noticed that the STW Inverse Presets weren't indexed since I never use Native or DSP verbs much. But the Reverb sounds excellent, hence the decision for further math & science. RMX160SC's also sound good, but less editable, and less DSP too.
Now that the STW Inverse presets have been indexed, I can load the project up with the effect loaded on the toms in the saved project ( also start up default ) and no more Error messages referring to the Lexicon which is an emulation of Space, but coming from the STW Inverse which is an emulation of the emulation.
Major Coolness...
Major Coolness...
