hi
I need a device that works as a parralel line
lets say mono vocal in and split that up in 4 mono signals.
its like on a pro patchhbay on a bigmixer
it works really fast and easy !
mono in and 4 time's out , who can help me !
And a matrix would be nice last say
12 inputs and 16 outputs somthing like a matrix console on a midas live desk.
Okay dokters let magic begin !
ronald meij.
parralel lines
um, just run four lines from the output of your vocal. (you DO know that you can run multipe signals from one output [even inputs can be rerouted to other inputs - just not more than one cable into an input is the rule]). of course all of this is covered in the manual. what is the point of making a device for this?
or I have gravely mistook your meaning . . .
[ { ( - algorhythm - ) } ] /
<font size=-1>[ This Message was edited by: algorhythm on 2001-10-08 19:33 ]</font>
otherwise u will use the dsp because u use the mixer then.
lets say split a asio output 1 up in to four channels en directly to a a16.
If u work with a external mixer.
or for special effect purpose , special triggering and gating.
It works faster and it keeps the dsp down.
Thats all , a real studio works with parralel line's , so i would like to see it also in a desktop system.
nope no mixer - analog or asio in module, say ch1, out to 4 FX channels; hell, you could send it to 64 if you wanted to.On 2001-10-09 01:39, ronaldmeij wrote:
and of course, you could make a "parallelizer" in the modular if you want to waste dsp for something that can already be done simply and easily with mere cabling . . .
