Hey guys,
i'm totally confused with creating the surface-design in SDK...
I do not get the logic behind and i'm missing a lot of "surface-thingy's" like "ModuleDrop" or something to create the surface...
In case of Circuit, my first bigger device works tough, but you need a good surface - anybody out there who can help me a little bit via Instant Messaging or something?
Greetings,
Robin
Scope SDK - Surface-Design help
Re: Scope SDK - Surface-Design help
You should have 2 folders called 'Device Design' and 'Surface Design' which contains templates and modules to build your surface.
yes, i know, but there are a lot of things missing!Warp69 wrote:You should have 2 folders called 'Device Design' and 'Surface Design' which contains templates and modules to build your surface.
take - for example - the "InsertSlot S".. there you need a ModuleDrop for the Slot in the GUI - i can grab it out here, but can't find that in the Surface-Design...
Additional, I can't get it working to get a "DefaultPanel" with a button or something - it just won't work if I put in a "Button" under the Tree of "DefaultPanel"...
HEEEELP!
Oh yes. That's why we have uploaded additional documentation in one of the threads. There exist a lot modules not present in the current version of the SDK.thehe wrote:yes, i know, but there are a lot of things missing!
Correct - you'll have to copy the 'Insert Load' section (under Panel) in the 'InsertSlot S' module and paste it to your own panel.thehe wrote:take - for example - the "InsertSlot S".. there you need a ModuleDrop for the Slot in the GUI - i can grab it out here, but can't find that in the Surface-Design...
I might not understand your problem - you're starting with the Empty Effect template?thehe wrote:Additional, I can't get it working to get a "DefaultPanel" with a button or something - it just won't work if I put in a "Button" under the Tree of "DefaultPanel"...
not really... the module is really heavy and i started it from scratch (i didn't want to have the text-thingys with "here put your output" from the templatesI might not understand your problem - you're starting with the Empty Effect template?
so... the default-panel in SDK is fixed size and does not show ANYTHING i paste in there... :/
Press the edit button at the top of the environment - then you're able to delete the text 'Connect the audio inputs.....' etc.
Then move your algorithm module to the Empty Effect module and start from there.
thank you very much, i'll try that!Warp69 wrote:Press the edit button at the top of the environment - then you're able to delete the text 'Connect the audio inputs.....' etc.
ok so there is a basic knoledge to this ,,,,,,,, not tooo complex
just connect a button or knob to the pad val
you have a Dsp moudule and you got a serface insrance
(panel is a moudule with strings var etc on it)
bassicly the best way to desighn a surface is to connect knobs to well you decide
som5 you get export errors
