Scope 5.1 No sound by Pressing key MasterkeyB in Cubase 5.1
Audio-Active
Post by Audio-Active »
Hello
If got a 17 64bit win7 with Scope PCi 5.1 using cubase 5.1
n Ableton every thing is oke, sound, midi, everything also the masterKB gives sound by pressing a key.
but in Cubase every thing works, Sound, midi, i can se and hear. even when i paint a note it give's a sound.
only buy pressing a key on the masterkeyboard there is no sound????? im buzzy whit for a view days now..
is it the version 5.1, (AiR crack)?
it must be CB.. but can't find out what.. who can help me out!!????
Greetz Jerome
Re: Scope 5.1 No sound by Pressing key MasterkeyB in Cubase
Can you post a pic of your Scope project, so we can see MIDI routing ? Also, have you used the MIDI monitor to confirm MIDI flow in Scope project.
Mr Arkadin
Post by Mr Arkadin »
Perhaps you should try purchasing Cubase rather than using a crack.
all bets are off with a crack. if things don't work right, it's no surprise.
Audio-Active
Hey!
I'fe used the imdi monitor and my project is allrigt, seg midi source dest all good that's not the problem.
idd A crack, uhh bad he. i starting to believe that the problem, i should buy CB... it must be,
in Ableton everything works so!!..?
Scrap some monny and buy..
But Thangz Guys.
Greetz Jerome
