If you do how?
Gtz Jerome
Anyone got the sts working on 64bit??
Re: Anyone got the sts working on 64bit??
if you read the letter that came with your upgrade, you'll see that STS does not work in 64bit. the sampler needs to use system ram and there are system files that must be rewritten for 64bit. it will likely be done, but there are several priorities before that can be done.
Oke!! thX i didnt see it in the letter. but SC is working on it so i see!.or am i wrong?garyb wrote:if you read the letter that came with your upgrade, you'll see that STS does not work in 64bit. the sampler needs to use system ram and there are system files that must be rewritten for 64bit. it will likely be done, but there are several priorities before that can be done.
i realy like the STS so i hope for a Fix soon!
ThX for you Reply garyb!
Greetz Jerome
