question about sync plate
bosone
Post by bosone »
i'm thinking about buying a sync plate for my system.
i have:
1) fostex vc8 ADDA
2) behringer vamp pro
3) pod pro
1) is connected with optical adat both in and out and can be either master or slave. i normally use it as slave with scope as master so i have no problem
2) and 3) have only spdif out and i can connect it digitally (spdif) only if i set them as master in the SFP control panel. that's rather annoying! :)
what if connect 2) and 3) to the sync plate via the wordclock? will they operate as slaves and will i get both the spdif outs for vamp and pro simultaneously in scope with no problems?
thanks!
Re: question about sync plate
yep, that's how it should work, if all of them have a bnc wordclock in, and you also purchase a masterclock/distributor. the cheapest masterclock is made by ART, i believe.
bosone
Post by bosone »
wtf! i did not know about the masterclock distributor!!!
i thought to connect my 3 devices in series with a cable and the T connectors...
thanks for pointing out this, i will investigate!
t-connectors would work, but they would also be unreliable.
