SCOPE 5.1 on Luna Card
mausmuso
Post by mausmuso »
I am an XITE-1 user, but I also had an old Elektra card in a second PC.
I decided to upgrade this card to PCI 5.1 as part of the Revolution offer.
I am so glad I did.
Now I have a second machine that can run samplers and most synths (albeit not all at once ofcourse)
Everything works including Minimax, Vectron, Mod 2 & 3, B2003, SB404, UKnow007, Blue Synth, Poison. Prodyssey.
I can load things like VDAT (although I have not used it as yet)
You can load a synth or sampler and Masterverb pro and the 1632 mixer at the same time.
This all means I can load some things that dont currently run on SCOPE 64bit.
RD DRum loads, although some of the factory presets cause DSP overruns. The sequencer works and as long as you only use 6 channels you can use this with no issues.
Similarly, the sequencer in SB404 works fine.
Using STS5000, I was able to load 8 channels opf samples without any issue (maybe thats mpore abpout RAM, than DSP).
The down side is the number of outputs.
I am using only the anlalog stereo outputs so far, so I dont have any sync or latency issues.
For those that have an old card lying around - you should have upgraded!!
Thanks Sonic Core for a very generous offer
maus
YISH313z
Re: SCOPE 5.1 on Luna Card
Post by YISH313z »
Same here. But I am able to get about 18- 21 voices of sts5000, the latter without a mixer.
mausmuso
Post by mausmuso »
I see the upgrade to 5.1 is now at 159 Euros.
Even at that price 3/4 dsp users get an enormous gain in functionality and usability.
One of the things I will now be investigating is whether I can sync (via MTC) this card to my ADAT so I can upload some old ADAT recording into VDAT.
This does not work currently in the 5.1 64Bit version.
Add to that the (requested) possibility of Open Scope being able to recognise both Scope PCI and Scope XITE on the same host....woohoo !
http://www.the-new-world-of-music.net/f ... b24825cf3c
