New motherboard+cpu with Scope (3 PCI Slots)
ehasting
Post by ehasting »
Hello,
Due to weird instability problem with my last configuration (and too much heat generated from the graphic card), i decided to swap out my mother board, cpu and ram with some more up 2 date and also with 3 pci slots instead of 2.
I must admit that its a big risk just buying new hardware for a scope system without even checking any reports, but thats what i did. and it is ROCK stabile!! :D
Following configuration is now in use with 2x Pulsar 2 + 1x SCOPE (15dsp) card. I get 13 master verb running (sounds rather eventide when trying to play the synths directly through them all :P).
I selected an CPU with low WATT consume, to get the temperature down, i wanted to have integrated graphic card. The ram is selected from the recommended list for the motherboard.
So this is what i have, hope it can be of help :)
( i have turned off internal sound card and USB3 in the bios, rest is running on default).
AMD A-Series A6-3500 Socket- FM1, Triple Core, 2.1Ghz, 65W, 3MB, Radeon HD6530
Kingston ValueR. DDR3 1333MHz 4GB, CL9 Non-ECC, 1.5V, 512Meg x 64, 240pin
ASUS F1A55-V, Socket-FM1 ATX, A55, DDR3, 2xPCIe(2.0)x16,CFX,SATA 6Gb/s, USB3.0, VGA, DVI, HDMI, EFI
Rgs
Stabile Scope User :).
Higen
http://www.higen.org
Re: New motherboard+cpu with Scope (3 PCI Slots)
ASUS P8Z77-V LE is as good as it gets for DSP cards.
Personally, dont know if they work, but Newegg always take back hardware within 30 days.
http://www.newegg.com/Product/Product.a ... 6813131823
MSI P55 CD53 actually appears to be designed for 3 x full length 32bit cards.
The SATA ports are totally out of the way. I always liked the 90 degree angles too, it shows they spent a few extra pennies.
