I know that this question is not related to Scope or any Creamware/SonicCore products specifically but since the Intel DP35DP is somewhat of a recommended reference mobo for Creamware/SonicCore cards and since Windows 7 64-bit is the new standard I guess it's important to get all of this running - so it's not irrelevant to what we do here.
My question is: Has anyone managed to fully install the DP35DP mobo drivers in Windows 7 64-bit? By "fully" I mean: To get rid of that "IDE Simple Communications... " ... whatever... device that pops up in the device manager as an uinstalled device after the Windows installation finishes. From that I can gather it's the onboard audio chip and other onboard stuff that are handled by this device but it seems like there are no 64-bit drivers for this (not on the Intel site anyway).
Have anyone of you solved this? Or is it solved by a complementary Windows update after the initial Windows installation? Since I'm having other Scope 5.1 trouble related to Windows 7 64-bit at the moment I want to rule out the mobo drivers as a potential error source.
Thanks,
Tomas
Intel DP35DP drivers in Windows 7 64-bit
Re: Intel DP35DP drivers in Windows 7 64-bit
I have moved onto the i7 and a newer i7 and the Z77 chipset.
But I had a DP35 Intel mobo working in x64 prior to updating.
I usually wait a while before I update PC parts, but the Z77 was an experiment.
I had incredible stability w/ the Intel DP35 though in x86 and x64.
Thier newer boards are nowhere near the quality of the first i7's.
Thanks for letting me know
. I'm just curious how you got the onboard DP35DP audio working in x64. Did you find a 64-bit driver? Or did you turn off the onboard audio in the BIOS an uninstalled the device in the device manager and everything just worked after that?
Thanks,
Tomas
Thanks,
Tomas
