Anyone?
I'm trying to build a mini ITX PC... a 75W PSU is enough?
The MB is a Asrock PV530 ITX with built in Via PV530 CPU (1.8 ghz)
The system usa (at max extreme usage) 53W, so for Scope remains around 22W to operate, it could be enough?
Which is the watt consumption of a Scope 6 DSP?
Re: Which is the watt consumption of a Scope 6 DSP?
bump, no one knows that?
22W at 5v is ~4 ampheres. but the sharc processors use 1.2v in the core, and the analog devices spec says max 1amp. 6 dsps = 6Amp @ 1.2v = 7.2W. Then add a little overhead for the rest of each chip, and you should still have plenty of room for the ADC and other electronics. My best *guess* is that you should be fine, and the boards probably use about 12w total
I has sense... thansk a lot JK!
From the latest #22 ScopeRise, it sounds like this is working...what were your final specs, and how well does it work?
It is in the manual
Scope 15 W
Pulsar2 12 W
Luna 6½ W
Luna converter 4½ W
Scope 15 W
Pulsar2 12 W
Luna 6½ W
Luna converter 4½ W
If U use a SSD HDD and a MB featuring Intel video chip inside, 75W PSU is enough
- SSD Kingston 64GB (new old stock, very cheap and fast indeed)
- MB Asrock PV530 ITX with built in Via PV530 CPU (1.8 ghz) and built in videocard
- mini ITX case with 75W micro PSU. NO FAN!!! External wallet. So it's like to switch on a DVD player = absolutely no noise (apart those form Scope Modular...
- PCI extension flat cable (a bite expensive...) to place Scope parallel to the MB and not, as usual, perpedicular into the PCI socket.
- Scope setted to start with windows, video, keyboard, mouse and MIDI controlled via network with Real VNC
basically an external MIDI half rack 1,5U
