To install and work with Scope on Win8 64bit you have to run Windows in testmode:
(The only reason why Scope doesn't run under Win 8 is because the drivers are not signed for Win 8.
FU Sonic-Core!!!)
1.
run execute as administrator -> cmd.exe -> bcdedit.exe -set TESTSIGNING ON -> restart.
Now install Scope PCI.
2.
Go to C:\Program Files\SCOPE PCI\App\Bin, right-click Scope.exe -> properties -> compatibility -> activate "run program as Administrator".
Build your XTCProject.pro, if you like to.
3.
For XTC Mode only 32bit Hosts work -> Install for example Cubase 32bit.
You have to run Cubase as Administrator too.
Tell Cubase where your XTC-Plugins are placed.
Thats it.
Some Bonus:
Now the Sampler "STS 5000 x64" works in XTC Mode. Do the dll-Trick for it.
Have fun.
Win 8 64bit, XTC - Mode, Cubase ----- Tutorial + STS 5000
Re: Win 8 64bit, XTC - Mode, Cubase ----- Tutorial + STS 500
What's the "dll-Trick"?
Each XTC-VSTplugin has an dll in the designated vst-folder.
Just pick another XTC-synth and rename it from say: MINIMAX.dll -> STS 5000.dll
The renaming is the dll-trick
However, I can't make XTC-mode run stable on my machine running windows 7. IT crashes after a while both in Live Suite 9.2.3 and Cubase 7.0.
If anybody has it running without crashes under windows 7 + Live/Cubase I'd like to know more about how they made it work.
Cheers,
Thomas
Cheers,
Thomas
For Live, you must run as administrator, and also turn off multi-processor in the settings.
Configuration->Multicore/Multiprocessor = OFF.
From what I could figure out, Live can place each track on it's own processor, and I don't think it does much to keep them phase aligned. This confuses SCOPE XTC.
If you have a Preference setting for PLug-in buffer latency, set it to be the same as your ASIO latency.
Sucks to limit Live to a single core, but since your using XTC plugins, that might not be so bad.
Cubase, Live and Scope are all running as administrator, I have also turned off multi-processor under the settings in Live. (And my bios has been optimized for Scope as weel).
I havn't tried the Plug-in buffer latency step yet though.
And we're overlooking the fact that STS works in Windows x64, I assume by using it within a x86/32-bit application?
So, all we really need is a wrapper for STS to run as 32-bit within SCOPE?
SilverScoper
