Focusrite Octopre MKII with XITE-1
rhythmaster
Post by rhythmaster »
Just one question:
Is it possible to connect the Focusrite Octopre MKII to the XITE-1 via the 2 ADAT Out's of the Focusrite Octopre MKII in the
"4 Channel per Port-Mode"?
http://global.focusrite.com/mic-pres/octopre-mkii
It's ADAT spec is as:
Digital Channel Outputs:
2x ADAT Lightpipe (TOSLINK) outputs. Provides 8 channels per port (16 total) at 44.1 and 48kHz.
Provide 4 channels per port (8 total) at 88.2 and 96kHz (S-MUX).
Does this work with the 2 ADAT INs of the XITE-1?
Harry
XITE-1, Cubase Pro 10.5 - WIN 10 64-bit
http://www.seismofunk.com
Re: Focusrite Octopre MKII with XITE-1
yes, cards and Xite are s-mux mode compatible :-)
rhythmaster
hubird wrote:yes, cards and Xite are s-mux mode compatible :-)
Thanks hubrid. Going to order it :D
spacef
Post by spacef »
I don't know if you bought it yet, but you may want to know that the Focusrite will have to be the master clock of the system.
It does not have adat inputs, only outputs, and can only send clock, not receive it through adat. I have not tried with wordclock which seems the only way to slave it to something.
It is not a big deal though, nothing "bad" in this. focusrite to xite adat a or b, and xite in slave mode.
I may want to sell mine now that I have the a16ultra repaired and the 2 xite preamps, but not 100% sure yet.....
plug-ins for scope
SpaceF website
SC website
Jah Servant
Post by Jah Servant »
The MKII has ADAT in.
rhythmaster
I bought it and it works only in Sync Master Mode via ADAT with XITE-1.
Via BNC I didn't manage to bring it in synx. I connected the cable but no "locked" status on Octopre...
What do I have to set up on XITE?
I checked the "BNC" - box in the sample rate settings - but nothing happens. Maybe a cable-issue?
rhythmaster
Ho!
When I run Cubase 7 in XTC-Mode, Master as "BNC" is working with Octopre MK II :)
it's locked now ... hmmm
pm me.
i'll send you a helpful file.
