MIDI Out
MIDI Out
Anyone ever notice that even when the XITE-1 hasn't loaded a project, that the hardware MIDI outs are active...
I screwed up and started playing w/o the project loaded and noticed my SE-1x which is connected to the MIDI Out (hardware) was switching presets.
Pretty cool...
Pretty cool...
- Bud Weiser
Re: MIDI Out
No, never tried that.dawman wrote:Anyone ever notice that even when the XITE-1 hasn't loaded a project, that the hardware MIDI outs are active...
Pretty cool...
You mean, w/ XITE and computer powered up but NO project loaded incl. hardware MIDI source and destination, XITE MIDI In is echoed to XITE hardware MIDI Out,- or is it MIDI Thru ? Or both ???
IF both,- that could be a hardware bug like w/ the old Roland MKS80 echoing incoming MIDI to MIDI Out always, creating a MIDI loop when using bankmangers/editors, then resulting in corrupted sysex files.
MIDI ECHO is a feature and should be on/off switchable on demand, which in case of SCOPE/XITE, that would require an already loaded project,- at least because, if not switchable, MIDI filters were the workaround.
Re: MIDI Out
Well I don't really know if it's Thru Or Out, but it sends LSB/MSB and PrgmChng, FilterFreq CC Sweeps, etc.
I was surprised.
I suppose on start up the Sequencer MIDI Destination is merged with it.
On occasion I was getting stuck MIDI notes, and all day today I tried my hardest to get stuck MIDI notes with Hardware MIDI Destination disconnected, and realize this dual MIDI stream was the problem.
This only took 3 years but it's all good....
I was surprised.
- Bud Weiser
Re: MIDI Out
It´s important to know,- if it happens w/ gear connected to MIDI In, MIDI Out and/or MIDI Thru,- please double check.dawman wrote:Well I don't really know if it's Thru Or Out, ...
In your former post you said "hardware MIDI connections ACTIVE",- right ?
Now, when you have connected an ext. MIDI device´s MIDI Out to XITE-1 MIDI In and there´s another external MIDI device connected to XITE-1 MIDI Thru AND a next one to XITE-1 MIDI Out,- all w/XITE-1 powered up, connected to computer, a SCOPE project loaded but NOT containing any hardware MIDI I/O device,- any connectivity between XITE-1 MIDI In and MIDI Out should be impossible,- right ?
If NOT,- that´s weird !
But, the connectivity between XITE-1 MIDI In and MIDI Thru is in hardware and done w/ opto couplers, me thinks.
Like w/ any other MIDI module powered up,- MIDI In is always connected to MIDI Thru and that would be normal.
Is merged with what ?dawman wrote: I suppose on start up the Sequencer MIDI Destination is merged with it.
Me, using SCOPE 5.1 on XITE-1 and WinXP SP3 32Bit,- I have to make connections in routing window between hardware MIDI I/O (XITE MIDI src & dest) and sequencer MIDI I/O devices (seq MIDI src & dest) before these work.
But you use SCOPE 5.1 64Bit AFAIK,- right ?
Up to now, I don´t understand from WHERE the misterious "dual MIDI stream" came and to where and what it is/was transmitted.dawman wrote: On occasion I was getting stuck MIDI notes, and all day today I tried my hardest to get stuck MIDI notes with Hardware MIDI Destination disconnected, and realize this dual MIDI stream was the problem.
What routing scenario did you have w/ your masterkeyboard (Casio ?), Solaris and SE-1X and which device was affected by occasional stuck notes issue ?
Which startup project was active at that time w/ SCOPE and XITE-1 up and running,- screenshot available ?
Re: MIDI Out
OMG, now I forced to reveal to the world I am dyslexic, all of these Out to Ins in hardware were OK, but the PC stuff reverses that and I get confused.
I shall try and use some screenshots, while I recover. I usually create some stuff on Channel 11 of a mixer as I can easily deal with the 2 x 1's...Then I can unconfuse myself.
Give me 10 minutes to re create my set up using screenshots and low quality Phone jpegs.
Re: MIDI Out
OK here's the deal.
Before the XITE-1 project is even loaded, my SE-1X was recieving note on/off and MSB/LSB, PrgmChng data from the XITE-1 MIDI Out, hardware that is.
Then I load the project and the XITE-1 MIDI Out gets shut down.
Then I go to the project window, and disconnect the XITE-1 MIDI Destination module and I get no sound, no MIDI data transfers either.
It's a peculiar oddity I never noticed. But on my 88 note controller prior to the project being loaded, I can see the SE-1X reciveing note on/off, PrgmChng, and MCB/LSB data.
Once the project is loaded, the XITE-1 MIDI Out is now what is sending data to the SE-1X. So the virtual MIDI module has now taken over and is sending the data from the hardware MIDI out, so this isn't a dual stream actually, but a switcher type of action.
I disconnected the XITE-1 MIDI Destination module and the SE-1X recieves nadda, nothing.
Very unique scenario I never noticed before.
This tells me that during a shutdown/reboot, if I ran extra outputs from the Analog out of Solaris, I could switch from Bank 8 where my programs are stored using the Toslink to AES/EBU connection on the XITE-1, and go to an exact Duplicate of that Bank, only Bank 7 would have the Analog outs instead of the digital, and my 88 note controller could still control the SE-1X via the XITE-1s hardware MIDI out.
I would have to use the Barbettas and only change Banks on the Solaris, and shove the Analog out of the SE-1X "y'd" analog cable all the way into the Barbettas, as they have a Mixer/PA interface in the rear where Hardware effects loops, and multipole I/Os reside.
This is pretty good to know, but Scope has never crashed on me...ever. Years of 6 nights a week and not once have the cards, or the XITE-1 ever crashed. It was one of the reasons I stayed with Scope once I had the choice of buying a Receptor and hardware, or the XBox. I am glad I stayed the course.
I hope I made sense, as my head is still spinning from the talk of multiple I/Os from hardware to multple I/Os of software, which are reversed for the sake of virtual routing......Sheeez...I need a Jager.
Re: MIDI Out
Sorry about the confusion of which hardware out I was using. I never use Thru.
At NAMM I was suppose to set up on another controller I was unaccustomed to, and use my SE-1X, and as soon as GaryB started talking about Thru to this and that my head started spinning so I decided to just shut up and play. It sucked, but cowering away was no option.
I was using a crappy Synth Brass from a synth in Scope from the Akai 88 noter, and just ran with that.
My Bassist was quacking for effects like a girl singer and tormented GaryB even further, so I was just wanting to hurry up and play, then cower off into the crowd afterwards.
At the end of the day, I am really a Simpleton, lost on any other app than Kontakt and Scope.
You should see me go into convulsions after reading Threads at the Reaper forum when they start talking about a tracks I/Os and various I/O options. My head spins right off of my shoulders.
Hope this helps explain what I discovered.
- Bud Weiser
Re: MIDI Out
dawman wrote:OK here's the deal.
O.k.,- let´s go step by step:dawman wrote: Before the XITE-1 project is even loaded, my SE-1X was recieving note on/off and MSB/LSB, PrgmChng data from the XITE-1 MIDI Out, hardware that is.
SE-1X MIDI-In is connected to XITE-1 MIDI-Out (which is XITE-1 MIDI destination).
Normally that means,- there isn´t the XITE-1 MIDI destination device loaded in that project or,- it is loaded into that project but it´s not wired to any MIDI source.dawman wrote: Then I load the project and the XITE-1 MIDI Out gets shut down.
In both cases,- no MIDI info at XITE-1´s MIDI-Out.
Isn´t that normal ?dawman wrote: Then I go to the project window, and disconnect the XITE-1 MIDI Destination module and I get no sound, no MIDI data transfers either.
1.)
that line verifies there is the XITE MIDI destination loaded into that project because otherwise you´d not be able to disconnect it.
2.)
Probably because of a up to now unknown sequential order of devices loading while the project loads and w/ outboard hardware already connected (SE1-X /XITE-1 MIDI-Out),- it might be, XITE-MIDI destination was already active before the project loading procedure was finished completely and there was a MIDI info stream being transmitted to SE-1X until something broke when the project loading procedure was finished,- maybe the MIDI line running from (?) wherever to XITE MIDI destination (XITE-1 MIDI-Out),- so any transmission of MIDI info stopped.
Well, that´s hard to find out and could be a bug which happens occasionally only,- but also would have to be reproduced repeatedly to confirm it´s a bug.dawman wrote: It's a peculiar oddity I never noticed.
To me,- it appears to be a software thingy.
Now we come to the point where it´s hard to follow.dawman wrote: But on my 88 note controller prior to the project being loaded, I can see the SE-1X reciveing note on/off, PrgmChng, and MCB/LSB data.
IMO what you see on your 88 note controller is what it transmitts,- not what SE1-X receives.
Assuming your 88-note controller´s MIDI-Out is connected to XITE MIDI-In (XITE MIDI source in the project) and SE1-X is conncted to XITE MIDI-Out (XITE IDI destination in the project),- how comes you have any visual info on your 88-note controller about SE1-X receiving MIDI info ?
Where do you see that,- in the display of the 88-note controller ?
That said,- it would be only possible when your controller supports such a feature and when SE1-X supports that too by reporting received MIDI Info via it´s MIDI-Out back to the device connected to it´s MIDI-In.
(think of it like a plugin reports parameter status to the Behringer BCR2000 in a bi-directional MIDI setup).
You use a Casio controller and I doubt it supports that,- in fact, I don´t know any keyboard MIDI controller supporting this, except the Panorama P4 and P6 specially designed for Reason,- and I also doubt SE1-X does.
But (!!!) - IF the SE-1X MIDI-Out is connected to somewhere MIDI-IN in that hardware MIDI setup w/ several MIDI connections made in the SCOPE project,- it´s imaginable you had a MIDI loop which stopped MIDI transmission.
Well, that indicates you probably had a MIDI loop resulting in a MIDI buffer overflow somewhere, which stops MIDI transmission and looks like a switcher type action for a period of time.dawman wrote: Once the project is loaded, the XITE-1 MIDI Out is now what is sending data to the SE-1X. So the virtual MIDI module has now taken over and is sending the data from the hardware MIDI out, so this isn't a dual stream actually, but a switcher type of action.
When you disconnected the XITE MIDI destination as described above, you probably killed the MIDI loop, resulting in normal operation later.
See above.dawman wrote: I disconnected the XITE-1 MIDI Destination module and the SE-1X recieves nadda, nothing.
Ehmmm,- now this is way too much off topic because the 1st target was to find out the MIDI issue in your hardware setup and SCOPE project.dawman wrote: This tells me that during a shutdown/reboot, if I ran extra outputs from the Analog out of Solaris, I could switch from Bank 8 where my programs are stored using the Toslink to AES/EBU connection on the XITE-1, and go to an exact Duplicate of that Bank, only Bank 7 would have the Analog outs instead of the digital, and my 88 note controller could still control the SE-1X via the XITE-1s hardware MIDI out.
Assuming you loaded a project you use frequently and in a never modified state and the project as well as the hardware setup worked before as it should and always,- you might have had just only a random occuring error.
I´d think of it in depth only when you´re able to reproduce the issue for several times.
From the very beginning,- I thought of a MIDI loop error but held back commenting on that, not knowing your MIDI hardware wireing and how the MIDI wireing in THAT project looks like.
In fact, I´d double check for any MIDI loops in SCOPE project when the issue comes back.
You use a lot of small MIDI devices in your projects like mergers, re-channelizing and such and if one of these little toys craps out in the project for a period of time (eventually during the procedure loading a/the project), there is a chance all comes from there.
But there´s also VST stuff involved in your setup,- so that might also causing a (non constant) MIDI loop somewhere while all is loading.
Me too,- NOW !dawman wrote: Sheeez...I need a Jager.
Re: MIDI Out
Heres my test results using my MIDI activity LED (TATTLETAIL)
1) XITE-1D Powered ON with Scope NOT loaded - MIDI OUT => TATTLETAIL glows RED
2) XITE-1D Powered ON with Scope loaded but project empty - MIDI OUT => TATTLETAIL shows nothing
3) XITE-1D Powered ON with Scope loaded and hardware MIDI IN connected to hardware MIDI OUT => TATTLETAIL shows activity ONLY when data present on XITE-1 MIDI IN (Behringer BCR2000 knob twisted).
None of the above surprises me at all - except case 1) above. So I connected Scope XITE-1 MIDI OUT to SCOPE PCI MIDI IN, and put a MIDI monitor on the PCI MIDI IN, and it showed nothing when Scope XITE not loaded and I twisted a BCR knob.
- Bud Weiser
Re: MIDI Out
That indicates there´s electricity active at MIDI Out when XITE is powered ON.dante wrote:Heres my test results using my MIDI activity LED (TATTLETAIL)
But Jimmy said: "but it sends LSB/MSB and PrgmChng, FilterFreq CC Sweeps, etc"
That´s what I expected,- so when Jimmy has seen dedicated MIDI data (like mentioned above) being transmitted w/ XITE-1 powered up but project not been loaded or while Scope performs project loading sequence but the procedure not being finished,- that data must have come from elsewhere in his hardware MIDI controller(s) and MIDI slave setup.dante wrote: None of the above surprises me at all - except case 1) above. So I connected Scope XITE-1 MIDI OUT to SCOPE PCI MIDI IN, and put a MIDI monitor on the PCI MIDI IN, and it showed nothing when Scope XITE not loaded and I twisted a BCR knob.
I´ve never seen that because I 1st power up XITE always, then load project and wait until it´s been loaded completely, then power up MIDI controllers.
It seems, he did/does the opposite,- MIDI controller (88 note keyboard) and MIDI slave (SE1X) already powered up, then loading project.
IIRC, there´s the/a Behringer BCR or BCF in the ballpark too in Jimmy´s rig.
Re: MIDI Out
I shall try and clarify a little more.
The XITE-1 is basically a MIDI Patch Bay when it's on but no Project or Scope App has been loaded yet.
Then when you load a p[roject MIDI Hardware Out is closed until project is loaded, where the XITE-1 MIDI Destination then assume the role of the hardware MIDI Out.
I hope that explains how the XBox works like a hardware patch bay it is on, w/o the Application running.....
Ankyu
Ankyu
Re: MIDI Out
Havent seen that. I get nothing (zilcho) passed from XITE-1D IN to OUT until a Project is loaded with MIDI patched.
Maybe its functionality revision patched out of units manufactured after first batch.
I havent tested the XITE-1D THRU, though I would expect it to behave as you describe (since theres no THRU device to drop into a Scope project it must be a hardware THRU only). But not the OUT. The OUT should only ever be active when made so by a project.
- Bud Weiser
Re: MIDI Out
Oops,- that, for the time being, indicates XITE MIDI-In is echoed to MIDI-Out as long there isn´t any project up and running and hardwired to MIDI Thru (using opto couplers) always.dawman wrote:I shall try and clarify a little more.
O.k. ...dawman wrote: Then when you load a project MIDI Hardware Out is closed until project is loaded, where the XITE-1 MIDI Destination then assume the role of the hardware MIDI Out.
No, just because "MIDI Echo" is a software functionality and normally not in hardware (in opposite to MIDI Thru).dawman wrote: I hope that explains how the XBox works like a hardware patch bay it is on, w/o the Application running.....
Ankyu
In a early post here, I was talking about the Roland MKS80 hardware bug by design flaw which showed the same issue, but constantly,- just because there weren´t any projects to load at all,- so when it was powered up, it was there until it was switched off.
In fact, if this is how your XITE-1 behaves, it´s worth a question to S|C developers if that´s intentional or not.
OTOH, it´s imaginable XITE at power up loads a hidden little firmware program which doesn´t need the computer and SCOPE environment to make sure all the hardware connections work.
That could work w/ the new Sharcs because these have RAM too.
When I have the time, I´ll try w/ my XITE-1, but all my MIDI gear is wired to REAL MIDI patchbays,- incl. XITE-1.
Re: MIDI Out
My bet is yours will be like mine, Bud, being a later manufacture.
Although you did say your's was sitting in shop for some time...so who knows.
Re: MIDI Out
It might be like our Oscilloscop , its actually sending electrical signals through turned off gear.dawman wrote:Anyone ever notice that even when the XITE-1 hasn't loaded a project, that the hardware MIDI outs are active...
Pretty cool...
Isn't that what Midi is about .
I mean its not depending on sound , so whats the issue.
Bear
- Bud Weiser
Re: MIDI Out
When XITE acts like a MIDI patchbay when powered up, w/ external gear connected (to MIDI-In and -Out) which is powered up too,- and streams incoming MIDI data to MIDI-Out even there´s no project loaded containing MIDI connections (XITE MIDI Source) to (XITE MIDI Destination) in SCOPE environment, there would be ...niceboy wrote: so whats the issue.
Bear
MIDI FEEDBACK in case you have a bi-directional MIDI connection w/ the same device,- p.ex. a MIDI sequencer w/ it´s MIDI Thru parameter set to ON.
MIDI hardware normally just only copies MIDI data from MIDI-In to MIDI-Thru,- not MIDI-Out.
If it copies MIDI data form MIDI-In to MIDI-Out,- we call that MIDI-ECHO which is a software feature in some hardware MIDI gear but not active by only powering up a unit (it could be a permanently storable global user setting though).
In some cases it makes sense to activate MIDI-ECHO, p.ex. when you want to control several identical MIDI devices´ parameters by only the 1st device in the chain or a (SysEx) software application running on a computer.
You can also control/play 2 different devices, 1 connected to MIDI-Out and the other to MIDI-Thru on 2 different MIDI channels and by the same controller that way,- but that should be user selectable.
In fact, it IS user selectable in SCOPE by making MIDI connections WHEN the project window is up and running,- but if it´s not, MIDI connectivity between MIDI-In and MIDI-Out should not exist.
If that is an issue or an "advantage" for some users doesn´t matter,- it´s a general thing w/ MIDI.
Re: MIDI Out
Yep, otherwise there would be no reason to have MIDI THRU at all if MIDI OUT doing the same jobBud Weiser wrote:In fact, it IS user selectable in SCOPE by making MIDI connections WHEN the project window is up and running,- but if it´s not, MIDI connectivity between MIDI-In and MIDI-Out should not exist.
Did you test what yours is doing Bud ?
- Bud Weiser
Re: MIDI Out
I think "MIDI-Thru" is a leftover from the times w/ no MIDI matrix switch boxes existing,- I never use MIDI-Thru because it adds latency.dante wrote: Yep, otherwise there would be no reason to have MIDI THRU at all if MIDI OUT doing the same job
MIDI Thru was made for daisy chaining and in real world it´s acceptable connecting one additional device to MIDI Thru,- not more.
Meanwhile, there are many keyboard controllers out there offering the old standard MIDI trio connectors, but offering also a hardware switch making MIDI Thru a MIDI Out, my Kurz PC361 p.ex.
Not yet.dante wrote: Did you test what yours is doing Bud ?
I have to find the box where I stashed all my little MIDI accessories 1st,- most I don´t use in my rig anymore.
There must be the Midisolutions mergers.
I´ll do the electrical test, nothing being powered up except XITE and connect the merger.
I´ll also connect XITE MIDI-Out to Kurz PC361 MIDI In and use the MIDI monitor, then see if there´s also data transmitted.
Next will be powering up the computer, launch SCOPE and see what happens.
Next,- load a default project w/ hardware audio/MIDI devices loaded and watch ...
I´ll repeat steps #3 and #4 w/ Kurz PC3 controller powered up already before XITE will be powered up and w/ bi-directional MIDI connections from/to PC361,- prewired.
That would be something compared to Jimmy´s rig.
PC361 is multitimbral and can act as controller and MIDI module simultaneously w/ MIDI local off.
That should clarify everything,- I hope.
Needs some extra time,- I have a busy month.
