Hi everybody (-:
When Im working with Akai samples that are 44100Hz, Should I set my project to 44100Hz? I was told that the samplers (i.e Halion, Sts...) convert the frequency of samples automaticly...is that so?
thanks
						Akai Samples & Sample Rate
Thanks (-:
So, Hmmm... I'm sure my question is somewhat stupid, I apologies, but still I don't get it..
Do I have to set my Luna project Sample rate
to the S.rate of the Akai samples I use?
Or will the Halion/STS change the sample's s.rate to the rate used in the project?
<font size=-1>[ This Message was edited by: 4nb on 2001-11-03 15:32 ]</font>
Thanks again [-:
Everybody please accept my apology for pushing this thread o-:
May I give this one more try:
Generally, When Working With sample's,
Do one have to set hes project s.rate
according to the s.rate of the samples he uses?
In other words: Is it possible to use Akai samples in a 48 or higher project?
<font size=-1>[ This Message was edited by: 4nb on 2001-11-04 12:57 ]</font>
No, you don't have to do that. The sampler fix this automatically. Although if you have a project thats sampled at
Of course, increasing the sample rate of the project should result in better sound quality if the samples used is either recorded or pitched to a samplerate that is higher than that of the project,but at higher dsp cost. This is theoretical so you probably wouldn't notice it though. It also depends on how the sampler handles filtering.
Bottom line: Use 44.1kHz unless you have a reason not to do so. The sampler doesn't really care that much.
