The patch can be downloaded here - http://www.bcmodular.co.uk/forum/downlo ... .php?id=74
As you can see, the patch has been created inside a CLM module and because it's a filter circuit jhulk has locked it to 1DSP so as to keep latencies in check.
While the CLM can be saved as a new module it is unfortunately rather bulky and this circuit weighs in at approximately 1.7MB in comparison to other much leaner BC Modular modules. Also, because the whole circuit has been locked to 1DSP it can only handle 4voices if you were to use it polyphonically.
However, since this patch was built entirely using BC Modular modules it wasn't too difficult for me to recreate as an optimized BC Modular module complete with popup control panel...
This module weighs in at 53KB and can handle 14 voices of polyphony
Download the module here - http://www.bcmodular.co.uk/forum/downlo ... .php?id=75
