Tanks for everybody. But my problem update continue. In my system boths version are inside.
Double click in V 3.0,and.... is working.
Double click in V 3.01...." Installation error: kernel file puls2os.21k not found or invalid. Pleaase check installation "
Driver is update before install V 3.01. No problem in devices manager
Alone in the dark ?.
Continue problem update V 3.01
if i were you, i uninstalled Pulsar3.01. My setup program wanted to install in folder c:Pulsar instead of c:Pulsar3. I think the same will be the case on your pc. verify your folders.
if a program doesn't run, i mostly try to gets the last update off and on again, closely monitoring the setup.
a t
m i c
a t
