A16 with Luna 2
thomashenrydavies
A16 with Luna 2
Post by thomashenrydavies »
Does the A16 work at all with the Luna2? I assume if it does, you only get 8 channels? Could you add a second Luna2 to the system and then get the full 16 from the a16? (Using Z-Link)
Re: A16 with Luna 2
yes, and yes, but z-link only with the older A16 Ultra. with the newer A16 Mk2, you would need to use ADAT.
there was an i/o extension for the 3 dsp cards if you can find one that has 2 ADAT connections and a z-link port, iirc...
