pulsar as UAD
Discuss Scope XTC mode.
pulsarll
pulsar as UAD
Post by pulsarll »
I have Cubase5 and use a firewire audio card as the main.
Can Pulsar2 plugins work in XTC mode in Cubase5 although I do not use a pulsar as the main audio device (like a UAD)?
Jesper
Re: pulsar as UAD
Post by Jesper »
pulsarll wrote:I have Cubase5 and use a firewire audio card as the main.
Yes it does. All the info you need is in this forum so do some search.
pulsarll
Re: pulsar as UAD
Post by pulsarll »
I've searched but did not find anything, if you know the settings link.
Re: pulsar as UAD
pulsarll
Re: pulsar as UAD
Post by pulsarll »
I know that. But I'm interested in options when the pulsar is not the main audio card in Cubase (which I wrote in the first post). How then run XTC mode?
ShogunSpy
Re: pulsar as UAD
Post by ShogunSpy »
As far as I know to run in XTC mode you need to be using Scope as a sound card! Try using it in SFP mode then you have endless possibilities ..:)
http://youtu.be/qK89jxQCnJg
pulsarll
Re: pulsar as UAD
Post by pulsarll »
ShogunSpy wrote:As far as I know to run in XTC mode you need to be using Scope as a sound card! Try using it in SFP mode then you have endless possibilities ..:)
Unfortunately it does not work because it also requires that pulasr be the main card.
Is there someone else some kind of solution?
Re: pulsar as UAD
you need to search for "Jumper trick"
http://forums.planetz.com/viewtopic.php?t=23125
that should do what you want. of course it's at your own risk(though it should be 100% safe).
still, i have the question of "why?". why do you prefer the firewire card as an interface? i seriously doubt if it offers higher sound quality. i'm just wondering. i don't really need an answer...
erminardi
Re: pulsar as UAD
Post by erminardi »
Yes, IMO the scope boards are still into the 5 best sounding card ever you can use in a PC.
The last USB products are only marketing and best compatibility with laptop, apart maybe RME.
But definitely not best sounding than a Scope/Xite (converters, etc.)
