VDAT Recording quality ?
shayart
Post by shayart »
hii
Is there a difference in the Recording quality Between VDAT And the Software sequencer (cubase)
Never use the VDAT....Am I missing something ? :roll:
shay dan
Re: VDAT Recording quality ?
well, VDAT is better sounding for sure, but it's not as user friendly as the sequencer. basically, VDAT is a virtual ADAT machine and it suffers from the same editing problems as the old tape machine. if you are just going to record and mix without editing, VDAT is the best choice.
ShogunSpy
Post by ShogunSpy »
From what I have read here on planetZ yes it's better to vdat! I will be testing this soon and doing comparisons
shayart
Post by shayart »
Yeah ... I'm going to record the stereo mix L And R From the sts mixer
I tried to record ... and it has recorded eight channel separate?
I want to record one stereo channel...How I do it?
It receives a separate signal ...And recording separate channels...
How do I record only the mix from the mixer?? :roll:
Thank you shay dan :)
as i said, VDAT is a virtual ADAT machine. it's almost EXACTLY an ADAT machine. ADATs don't record stereo. to record stereo, you'd need two mono channels, but then they'd need to be interleaved in another program.
shayart
Post by shayart »
I figured this would be a way...Thank you :)
The question is...after I convert them to a single file...It still maintains the quality of the recording?
Compared to cubase.."For example" ?
I mean ... other software it Through Export ...That's why I ask?
Currently I'm recording in real time my mixes...I come back From the STS mixer in another New channel in cubase ... and just recording all the mix...
it might be a little better to use VDAT, but i don't know if the trouble is worth the results. you'll have to hear it and make your own decision... :)
shayart
Post by shayart »
This is most true................ :)
Thanks again :)
shay dan
