What are the pros and cons of 64Bit?
I know it helps in terms of memory but creates more work for the CPU but how else does it help?
Does it help with algorithms and headroom?
Anymore info appreciated.
						64 Bit
Re: 64 Bit
Kontakt, Reason etc can fit more samples in RAM - that's it.
						Re: 64 Bit
even the memory advantage can be overcome by using JBridge...
				Music Manic
Re: 64 Bit
Do I keep dual core settings set to enable in the bios.
Do DAWs still run on single core? I've been out of the loop for a while.
I'm on intel Dp35DP
Thanks.
I'm on intel Dp35DP
Thanks.
Re: 64 Bit
dual core or even dual quad core processor?
no problem.
basic setup suggestions:
http://forums.planetz.com/viewtopic.php?f=3&t=31345
						no problem.
				Music Manic
Re: 64 Bit
Thank you.
