stereo to mono
stereo to mono
Is there a device in Scope that receives a stereo input and outputs it as a mono signal?
Re: stereo to mono
Yes. The channel strip panned hard left or hard right !
Re: stereo to mono
Yes, but no. It will not be summed mono. It will just be left or right.
Re: stereo to mono
you can do that with those devices :
http://gcluber.free.fr/scope/Mix2m-Mix2s.zip
Re: stereo to mono
not if you use 2 channels, each panned the same way....Immanuel wrote:Yes, but no. It will not be summed mono. It will just be left or right.
- sunmachine
Re: stereo to mono
The ControlRoom Device has a Mono switch.
Re: stereo to mono
I use the Channel Manipulator from http://www.shaynesworld.com
http://www.shaynesworld.com/images/chan ... ulator.jpg
- Bud Weiser
Re: stereo to mono
Site is down unfortunately.wouterz wrote:I use the Channel Manipulator from http://www.shaynesworld.com
Was/is that a free device ?
If yes, is there a way to get it, please ?
best
Melodious Synth is in the process of reorganizing and going through a name change. We are sorry but the radio station is now off the air. We apologize for any inconvenience!
In the meantime please visit Binary Sea for any updates on progress. Thank you!
- sunmachine
Re: stereo to mono
Shayne's Channel Manipulator can be downloaded here: http://www.planetz.com/Pulsar/files/dev ... ulator.zip
Here's his original post:
http://forums.planetz.com/viewtopic.php?f=16&t=14375
Re: stereo to mono
The Channel strip only has one channel. It can be done with i.e. the micro mixer, though. On Xite, the Dynamic Mixer use less resources, though, despite being more advanced.garyb wrote:not if you use 2 channels, each panned the same way....Immanuel wrote:Yes, but no. It will not be summed mono. It will just be left or right.
Re: stereo to mono
Ok then ... Two mono channels of the micromixer both panned the same way !!Immanuel wrote:Yes, but no. It will not be summed mono. It will just be left or right.
Re: stereo to mono
if the two channels of a stereo track are to be mono'd, well, then they aren't a single stereo track, they are two mono tracks that just need to be summed. no special equipment required....
