LUFS &/OR K - Meter capable analyser for Scope?
auntybiotic
Post by auntybiotic »
Greetings, all.
I am shifting to using to the Bob Katz K-metering system for mastering, anticipating a significant change in how 'loudness' will be regulated over the coming years ( & hopefully ending the loudness wars once and for all).
I wonder if there are any existing or planned 'analyser' plugs which use K-Metering, or any that can show LUFS?
I am looking at the Meterplugs stuff (K-Meter, Perception and LCAST vsts) but would prefer to stay in the Scope environment for all metering if possible to do so.
I already have the Wolf Audio packs which are great but don't show LUFS or K scale etc.
Cant seem to find anything else that does either but please correct me if i am wrong.
ANy suggestions?
Many thanks all,
Mark
mausmuso
Re: LUFS &/OR K - Meter capable analyser for Scope?
Post by mausmuso »
A number of years ago Shroomz (I think) developed a nice VU meter that had K scales (-12 & -14 from memory)
I can't remember the name of it, but when I get back in the studio I will post the details.
Edit: I just remembered it was called 'Peakaboo'.
Regards
maus
auntybiotic
Many thanks for the Peakaboo tip ! The problem is I cannot seem to find it for download. If it is a free one, would it be possible to post it in a zip file?
vascomusic
Post by vascomusic »
Check Shroomz 'Hightimes' meter.
It supports K20, K14 and K12.
Mr Arkadin
Post by Mr Arkadin »
For me, HighTimes does not work in Scope 5.1 PCI or XITE.
Post by JoPo »
Ah ?
Here, it works properly on xite.
I don't remember if it is this one but there is a device like this with which the Scope file doesn't want to open after saving.
Anyway, Hightimes works for me.
You can find it here :
http://www.hitfoundry.com/scope/
mausmuso
Post by mausmuso »
yes it works in XITE-1.
The version you want is Hightimes_S_03b.
If you can't find the file PM me and I send it thru.
Regards
maus
Mr Arkadin
mausmuso wrote:yes it works in XITE-1.
Yep that's the version I have. Doesn't work for me. :(
mausmuso
Post by mausmuso »
I know it sounds a little odd, but check behind your mixer, project window, etc.
I noted that when I opened it, the 'aways on top' button does not work.
I thought it had not opened, but there it was hidden behind the project window.
maus
auntybiotic
THANKS to all for this btw - will check it out
Yogimeister
Post by Yogimeister »
Couldnt find it on hitfoundry ....
But found this ... :)
viewtopic.php?f=5&t=26552&hilit=Meter
auntybiotic
thanks yogimeister ! that looks good. will download and check it out !
