I tried to connect unbalanced line level (-10 dBV) signals to the analogue XLR connections on the back of the XITE-1 using a converter cable XLR to unbalanced jack. But the level difference is to high. Would a +4 to -10 converter box help? I found this one:
http://www.aphex.com/products/124b/
Connecting unbalanced line level (-10 dBV) signals
Re: Connecting unbalanced line level (-10 dBV) signals
sure it would.
I also found a passive version:
http://www.thomann.de/nl/ebtech_hum_lin ... fter_2.htm
What's the disadvantage when compared to an active version (other that the lack of extra gain)?
well, transformer vs. ic.
for this purpose, i'd probably want the active one, because it will add gain when going from -20 to +4. i don't know if a passive box can do that. if it can, then either is fine. it's hard to say which would be more transparent.
I purchased a Sonifex Redbox RB-BL2 which has plenty of gain. Problem solved
http://www.sonifex.co.uk/redbox/rbbl2_ld.shtml
looks good....
