Scope 5.1 upgrade
grappa
Scope 5.1 upgrade
Post by grappa »
A couple of questions before I consider popping the above on the DAW;
1. Does 5.1 contain an updated WDM driver for the XITE?
2. Does the install retain all Scope settings i.e. just update? The reason I ask here is that we have all of our hardware interfaces defined as devices for ease of use and this would be a nightmware to have to recreate and break existing projects no doubt..
I have a 5.1 keyfile btw..
Appreciate any advice.
Regards,
Simon
Re: Scope 5.1 upgrade
1. no.
2. no user files would be replaced, but some global settings like the screen mode might need to be reset.
if you are using 32bit windows, i can't see much reason to worry about the upgrade. if you move to 64bit, you will need to use v5.1.
grappa
Post by grappa »
Thanks Gary.
32 bit so won't touch anything!
Regards,
Simon
