Midi switch
Midi switch
Post by JoPo »
Hi..
I'm looking for some midi switch. I've found one or two but they seems to not work 100%.
midi sw.jpg (6.01 KiB) Viewed 2387 times
So, I'd like to try others..
I have the Wolf midi on/off from his midi tool box but if you know some other, I would be very interested !
I'm not sure but I believe I've heard someone who said he was developing some of midi switch...... :D But it's possible I mistake my wishes with reality... :D
Thanks !
sunmachine
Re: Midi switch
Post by sunmachine »
Did you check out mausmuso's MIDI device?
https://www.scopeportal.com/mausmuso-mi ... er-router/
Re: Midi switch
Also PRJ Preset snapshots using MIDI Filters everywhere is awesome.
Plus they're screen set capable.
Having a MIDI Monitor attached to each Filter shows you they're working.
Maus stuff is pretty incredible.
Makes me wonder what an unpacked MIDI Filter would look like.
Re: Midi switch
Post by JoPo »
That's it ! I guess this is what I heard about...
But I'm looking for a simple 2 --> 1 midi controlable fast switch....
I'm modulating randomly some Scope device parameter And I want to disable this with a midi cc in order to modulate the parameter by myself, then enable the random lfo again. All this must work fast : take control for ¼ second, then give it back to random lfo...
A pity there is no modular shell with several midi i/o to create midi switch...
Ooops ! But I could do it by changing the midi channel in a 1 midi i/o modular shell....! One channel for the lfo, another channel for taking control ! I go right away to check if there are some modulable midi channel router modules !
Yes ! In BCmodular, of course ! :) It should work ! Viva el Scope !
Marco
Re: Midi switch
Post by Marco »
Use the Modular! This week I dived into Modular and what should I say, it is not that difficult.
