Probably a basic question for some of you.
Since I use scope I have always used the STM 16 32... I thought it could be the time to change this
My question is I used to connect the outputs of the mixer to my Asio Inputs like:
the Asio dest are:
1L - 1R : Main Asio input (maybe not becessary)
2L : Bass in Mono
all other inputs are the instruments plugged on the ADAT (note I usually have additionnal Asio dest to plug 10 14 15 16 outputs of the mixer)
Asio source are:
1L - 1R: Main Asio outputs
2L - 2R: control the tape echo loop
3L - 3R: the bass through BAM
This allows me to route in cubase eachinstruments to a separate input in cubase and to use the tape echo as a send effect.
How is it possible to do this with another mixer (24/48)? Should I connect all the Asiodest to the Mix outputs from the 24/48 mixer?
Note usually the ouputs 10, 14 15 16 are also connected to other Asio Dests.
Thanks !
