Just a quick vid of the Ambient delay. Also use of dNa Effects Rack
Turn your sound down before you play, i'm a newbie to video production and i'm not sure the levels were set right.
https://youtu.be/DGmc2rD3PH0
Fun with delays
- Peter Drake
Re: Fun with delays
Very nice
Re: Fun with delays
Definitely rich.
Add modulation through the ModWheel or an Expression Pedal.
I often use an Expression Pedal to add Detune to the synth and modulation to the effect simultaneously.
It would make the Prophet even fatter.
Ambient Delay sounds great.
SpaceF Delays are so diverse.
Even the older AUX Delay from Black Box had inserts for Filters or FX and built in MIDI Controlled EQ.
You could go lo-fi by pulling down lows and highs leaving only mids using his CC # devices and a fader/Expression Pedal.
I even used the SpaceF trick on ZebraHZ.
Combine those 2 lo-fi tricks w/ Delays and Modulations.
Ankyu
Ankyu
Re: Fun with delays
@dawman Thanks for the tips. I've got an exp pedal going into my Rev2 and a FCB for the midi into Scope.
My feet are just plain spastic so I am very thankful for the SpaceF CC devices for smoothness.
"You could go lo-fi by pulling down lows and highs leaving only mids using his CC # devices and a fader/Expression Pedal."
Would that give that sort of washed out effect on the tails?
Re: Fun with delays
Yeah, the instrument gives the tone, but if SpaceF has inserts use a Black Box Filter or really get big with Faxinadu’s Filter.
Re: Fun with delays
Well I will certainly try that out next week. I'm also going to be diving into the SpaceF Echo4 as well.
