Creating a simple Sine with ADSR
summer
Post by summer »
It seems I cannot get the gate to trigger the ADSR and I can't connect the frequency out from Pitch Modulator to Frequency in of Sine Oscillator
Do I need to put something in between those two connections?
faxinadu
Re: Creating a simple Sine with ADSR
Post by faxinadu »
go inside the sine and delete the panel
http://www.oceanswift.net
Music
summer
Post by summer »
Thanks that did the trick.
I can see note input being processed
And it responds to the pitch mod on my midi keyboard and the panel UI but not actual notes played from the midi keyboard.
Unfortunately I can find anything that helps me in the SDK4 manuals that explains how the voice controller can modify the frequency.
The gate out from the voice controller also doesn't seem to trigger the ADSR modulator.
I also tried the midi value extractor without luck.
Should I be contacting support via email for every question that I have?
Probably not, though I will defer to GaryB on that one for certainty.
This and the other Scope communities are still your best bet. Look for the SDK Wiki posts here and see what you can find from those as well.
faxinadu
Post by faxinadu »
- did you connect esync?
- from mvc you connect freq output to the sine freq input
Music
faxinadu
Post by faxinadu »
Music
Thank you Faxi =]
