DAS RODE Missing DSP - need help :)
LorenOA76
Post by LorenOA76 »
Hello Scoopers,
I am looking for a missing Dsp file for DAS RODE.
The missing file is:
DASX20.dsp
Many thanks in advance,
Loren
Re: DAS RODE Missing DSP - need help :)
Peter Drake
Post by Peter Drake »
You may find that keeping Scope under Windows 7 or older will fix this issue.
LorenOA76
Post by LorenOA76 »
Thank you for the TIPS and link to the forum discussion :)
It works now :)
Loren
np. thanks for what you do
BibbieMok
Post by BibbieMok »
Hi...It also occurred to me that a computer could potentially handle all of the DSP, leaving only DAC and and amplification external to a PC or source. This would require an interface with 18 channels in and out. Could an interface like the ones above be connected to achieve infinite channels? How would a PC manage to output the correct channels to the correct device if multiple interfaces are required?
BobbieMok, you don't seem to be using traditional spam techniques but I'm wondering if you perhaps posted erroniously.
Liquid EDGE
Post by Liquid EDGE »
LorenOA76 wrote: Mon Mar 02, 2020 11:48 am Hi,
It works now :)
Loren
Did you get the file dasx20 or was it something else that fixed it?
Liquid EDGE
Found it.. it’s included with the das legend files
BibbieMok wrote: Mon Apr 06, 2020 9:14 am Hi...It also occurred to me that a computer could potentially handle all of the DSP, leaving only DAC and and amplification external to a PC or source. This would require an interface with 18 channels in and out. Could an interface like the ones above be connected to achieve infinite channels? How would a PC manage to output the correct channels to the correct device if multiple interfaces are required?
nice spamming technique, but that is NOT how these things work. one could buy an RME card if that was the whole purpose. a computer could NOT do all the work done on the dsps AND run everything else, but that might be fine for many uses.
i removed your ad.
LorenOA76
Post by LorenOA76 »
Hello Dear Liquid EDGE,
Already Found it.. As you say .. it’s included with the DAS legend files install folders
Many Thanks
Loren
