Adat cables
Interference
Adat cables
Post by Interference »
Hi guys,
Which adat cable are you using to connect your adat extension (such as CWA16 or Ada 8200).
Any advice or reference is welcome 🙂
Thanks!
Re: Adat cables
use the basic cheap ones.
Re: Adat cables
Using monoprice toslink cables here.
The connector is the biggest issue, some are too large for side to side clearances (other ADAT connections), while others will either be slightly too large--or small--in the socket. This has been my main cause for needing new cables.
Amazon optical cables worked but slightly too large side to side fit. HOSA fine but a touch loose in the socket.
Interference
Re: Adat cables
Thanks for your Quick replies as usual!
