Hi
Is it possible to get modules all in one place from the drop down menus? If I add 3rd party modules to the main modular folder it doesn’t see them when I load a modular shell.
For instance could I have modules from modular I,II,III and IV plus Flexor available in the modular shell drop-down menu?
Drop-down menus
Music Manic
StaticPath |Re: Drop-down menus
Scope XITE\App\Bin\cset.ini
>check key
[StaticPath]
Modular=C:\Programme\SCOPE XITE/Modular Modules/
(path example to your modules)
the path can disappeared after a few installations, then create it again manually.
Ps.: Drop-Down-Menu module must drag+drop to modular window! one klick on module in menu will not load the module.
>check key
[StaticPath]
Music Manic
Re: StaticPath |Re: Drop-down menus
Great I got it thanks I had them in devices folder. Should I just keep the Empty shells and presets in the devices menu and the modules in the modular folder?Spielraum wrote: Wed Feb 01, 2023 2:19 am Scope XITE\App\Bin\cset.ini
>check key
[StaticPath]
everything in one folder has pros and cons, hence my recommendation
>> use the defaults during installation to keep the bindings!
>> device will only load its associated prestfile if the path is stored. otherwise it has to be reloaded manually.
>> You can also easily drag modular modules from the OS window into the modular window
here cset.ini example for optimal workflow, eg XITE (german, scope5, 2010)
[FileBrowser]
LastPath=C:/Programme/SCOPE XITE/Devices
[ReferenceResolver]
All files_Paths=C:\Programme\SCOPE XITE/;
Modules/Devices_Paths=C:\Programme\SCOPE XITE/Devices/;
Presets_Paths=C:\Programme\SCOPE XITE/Presets/;
All files_AutoUse=1
Modules/Devices_AutoUse=1
Presets_AutoUse=1
[StaticPath]
Modules=
Presets=C:\Programme\SCOPE XITE/Presets/
Bitmaps=C:\Programme\SCOPE XITE/MRC Skins/ (M3)
Devices=C:\Programme\SCOPE XITE/Devices/
Samples=D:\Samples\
[Path]
Music Manic
Spielraum wrote: Thu Feb 02, 2023 12:07 ameverything in one folder has pros and cons, hence my recommendation
[FileBrowser]
[ReferenceResolver]
Great stuff thanks.
All files_AutoUse=1
Presets_AutoUse=1
[StaticPath]
Modules=
Samples=D:\Samples\
[Path]
