optimaster wizard relation to presets ?
nebelfuerst
Post by nebelfuerst »
I'm loading my beloved preset in optimaster , then i run the wizard.
Now I'm wondering if I loose part of my loaded settings by running the wizard.
Re: optimaster wizard relation to presets ?
sure you do.
the wizard provides a number of choices.
personally, i adjust the compressor band outputs to match the inputs(as usual for a compressor) after running the wizard. it's fast and effective. there is no need for presets...i find that the first few choices are usually closest to correct, but ymmv.
nebelfuerst
I use optimaster just for the complete mix, at the very end.
The preset-names suggest it might be an idea to have several optimasters in parallel for different tracks of the song. (like voices and piano..)
Does this make any sense ?
no, not to me. :)
however, what works for you is important.
i use optimaster for final compression and some normalization on the entire mix. i usualy use a final limiter in the final mastering process, once all songs in a colection are complete... i am sure it can be used as you suggest.
nebelfuerst wrote: Fri Apr 28, 2023 12:53 pm I use optimaster just for the complete mix, at the very end.
It makes sense in the same way it makes sense to have bus compressors for each instrument group etc. Then a limiter on master bus as well per Gary's suggestion.
