When i play the STS 3000 i hear a fastidious "click"
HELP ME PLEASE!!!!!!
STS 3000 + Luna 2 = continuous click
What is your "attack" envelope set at? What kind of files are you using? Which outputs are you sending the programs out to on the sampler (individual or master or both?)
Remember with extremely <i>fast</i> digital envelopes, an attack time of 0 will give you a click (even on hardware synths with fast envelopes). Raising it just <i>slightly</i> above 0 will remove that.
Remember if you're sending a sound out an individual out to <i>remove</i> it from the main outputs, or you will probably get phasing.
Yes, you've got it. You can also get a click when there is voice stealing.
In this case, you will need to raise the polyphony for the device (Devices pulldown at the top of the screen in V3), and maybe give different priorities to the Sample programs you have loaded to give drums higher priority. You can also raise the number of voices per program.
Try muting all but the drums and be sure no clicks there, add a track in until you get clicks, then adjust polyphony until they are gone, and continue until no clicks.
