No sound from VST Instruments
glockh210
Post by glockh210 »
when trying to use VST instruments I am not getting any sound! I get sound from the midi wavetable setting but when i change this to a VSTI I get silence. What setting am I missing. I am a newbie and am finding this hard to get used to. SB live was so much easier. I am using Win XP, a Luna II, and the latest Cubase version. Everything else seems fine so far(I am getting sound from everything else). thanks
glockh210
Post by glockh210 »
I'm glad to see how many people view this and how few respond. very helpful...
subhuman
Post by subhuman »
Hey relax, sometimes we just have to think about what it is you're asking a little bit. :smile:
Do you have "ASIO Source" module wired up correctly in your project? Generally VST instruments output their sound using the ASIO driver you've setup. For a more detail on setting up ASIO for playback/recording in your project, <a href=http://www.planetz.com/forums/viewtopic ... um=1&9>see my post from a couple days ago - and sandrob's pictures directly above it.</a>
<a href=http://infinitevortex.com>Infinite Vortex Audio</a>
<font size=-1>[ This Message was edited by: subhuman on 2002-01-24 10:22 ]</font>
coc999
Post by coc999 »
in pulsar project you should connect asio out in one of the pulsar tracks on mixer.
(i think you did it).
every vst instrum has his own audio track
on cubaz mix table(check if it is not routed on a group with 0 volume).
is your asio driver ok in cubaz audio preferences?(i think it should)
what else?maybe have you not selected the instrument in the port column(this is not pulsar port1 anymore you have to choose the name of the instrument you want to play.)
what i say could look basic,but some of these things happens to me when i was
a budding pulsarian lost in the tech darkness he he he :smile:
i hope it is that,if not we will talk a again:)
glockh210
Post by glockh210 »
Thank you I will try these. Just a little anxious to get going. peace
coc999
Post by coc999 »
subhuman sorry :smile:but i have say somethin pretty like you at the same time (greenwich meridian)that's why i have not seen your post before.i'm gone to read the Sandrob "Lesson",i did not read it before.Really useful and fun:)
see you allllllllll lll l ll l l ll l l
subhuman
Post by subhuman »
coc999 - no worries - you were quick! But I beat you by 3 minutes this time.. :wink:
dbmac
Post by dbmac »
Make sure "midi thru" is enabled (on) in Cubase.
/db
